Wasn't sure in which forum to post the below link, so I've posted here. Retro cool looks (well, at least to us audiophiles 😀), and likely an conversation starter too.
Vacuum Tube Flash Drives Combine Old School, New School Tech
Uurgh! I hate pseudo 'retro' styling, and LEDs illuminating valves. Definitely not for me.
Geez, man, you're not going to install it in your next valve preamp project, it's a USB drive. It's a far more interesting looking USB drive than the boring plastic rectangular block I'm using now, that's for certain.
Dito. I have the same concerns.
But I respect others opinions
But I respect others opinions![]()
I'm also in this camp...
SteamPunk bothers me.. I would LOVE to see modern design that features the components (similar to our tube amps w/ the tubes on display, and the way Victorians built engines and things) but to simply add guilding and lights and copper disks for no reason is gaudy!
Obviously, just my opinion.
My valve amp hides them under a perforated plain black cover. You can just about see the heater glow through the holes. Each to their own.
My wife who is a design professional would probably like your cleaner design more than my tubes on display type. At least I don't cross the line and have other stuff that's not really in use hanging off the chassis 🙂
I know a lot of people will say it's all opinion and there is no right or wrong when it comes to industrial design, but my wife would certainly argue that point and thinks there IS a correct way. But we're way off topic by now.
About the OP, that would be about the easiest DIY project for any of us.. Go buy a small USB flash drive, a copper pipe end cap, some silicone sealant, an led, and BAM.. 10 min later you've got one.
The bigger challenge would be to ditch the Christmas LEDs and get the filaments to actually light up.
01-A, 101A, 201A, etc...
I think there's some anachronic irony there if someone makes an 01-A flash drive.
it's not actually being used, so 5v on the 6.3v filament might work. (the person who builds those things probably doesn't even know what a filament is) Not sure if it would be bright enough, though. That, and maybe making the base a tube socket or something less flashy than a pipe endcap w/ guilding tacked on, would change it from over the top goofy, to something interesting, in my opinion.
and sorry, I have no right whatsoever being a design snob.. I'm used to design snobbery, though, cause of Julie and her 2 design masters degrees 🙂.
I'll pass but not for aesthetic reasons, but more for the fact that I usually take a USB key and put it in my jacket or pants pocket. Wouldn't do that with a "very good" tested or "dead" vacuum tube though as I can't imagine having bits and pieces of sharp glass and metal jab into my leg and other body parts being all that pleasant.
Well... except maybe for the 7034 (staring at a 4X150A right now) vacuum tube as it has a more robust package, but there is always an exception to every rule isn't there?
I was thinking the same. I know I'd end up with broken glass in my pocket. 🙁 I'd make myself one (DIY!) if I weren't afraid to break it.
As we are talking about superficial appearance of an object, opinions are all there is!
No, I'm concerned about its functional aspect. As in, do I want a flash drive made of glass that can break when dropped and litter the floor with glass shards?
Bugger.
When I saw "Tube Flash Drive", I imagined a room full of valves with a USB connector hanging off the end 😀
cheers, Jacob
cheers, Jacob
Of course, as is your privilege. We were talking about appearance, where opinion is all there is. Later, the discussion was broadened to issues like safety, where opinion has to give way to facts.dgta said:No, I'm concerned about its functional aspect.
- Tubes / Valves
- Tube Flash Drive
