hello there,
i own a car audio shop in jakarta, indonesia...
i want to build a tube buffer for use in a car...
can anyone help me with schematic and etc ?
thanks before.....
thanks before.....
NeuSounds said:hello there,
thanks before.....
Unless you get involved with "inverter" circuitry, the "12" VDC available in an auto limits your options, severely.
The 6GM8 twin triode is a nice tube and it's intended for automotive service. 🙂 Simple 6GM8 section cathode followers (1/channel), using battery bias, might do the job for you.
What's the RMS voltage coming out of the "head"?
i got this schematic.....
want to know, what everyone think bout it ?can it work well on car ?
http://diyaudioprojects.com/images/...art=40&gbv=2&ndsp=20&svnum=10&um=1&hl=id&sa=N
thnks all...
thnks all...
sorry about the link...
heres the right 1 :
http://diyaudioprojects.com/Tubes/12AX7_Preamp/index.htm
thanks
heres the right 1 :
thanks
NeuSounds said:ussually from head comes 4volt, the bigger is 9volt....
If we use a 6GM8 section combined with a "1.5" V. cell for bias, 3 V. peak to peak, which is approx. 1 VRMS, is the maximum I/P allowed. To get that far, constant current sink (CCS) loading set for 1 mA. will have to be employed.
The beauty of the 6GM8 is its ability to function with only "12" VDC on the plate. 🙂 However, miracles are not going to occur. To handle a more than 1 VRMS I/P signal requires conversion of the car's "12" VDC into a higher DC voltage. All methods of conversion I'm aware of have their shortcomings. 🙁
thanks ELi D.
so what do you think bout this 1 ?
http://diyaudioprojects.com/Tubes/1...reamp/index.htm
can it work well ? on 12V DC ?
thanks
thanks
- Tubes / Valves
- Tube buffer for car audio
