Is it possible to test (and compensate) a circiut for aging tubes?
The actual circuit is my 12BH7A common cathode amplifier, with +B=300V, Va=150V, Ra= 15K, Ia=10mA, Rk=470Ohm (decoupled)...
If I test these values e.g. each 6 month, I will likely see a drift from original values, will this drift be due to aging...(?)
Could this drift be compensated (like bias adjustment in power amps), and by this increase tubelife in the circuit? This could be by changing the Rk to keep Va/Ia at original values...
Are there any guidelines for tube aging? Sometimes I read that a tube is measuring 95% of specified values, what parameters does this "95%" refer to?
If not bias point at predefined values, could it be gm?
