I can't believe no one jumped on this one.
Tuba goes higher, but looses efficiency down low ... Tapped Horn CAN go lower and louder, but is only good for 2 octaves max.
Home theater can use the 20-25 Hz loud signal of a really low TH, but then you gotta cross over at 80 Hz.
This question is so general, there is no right answer !!!
sooo... a th isnt that good for music. crossed over above 120hz?
As Alice said, "Would you tell me, please, which way I ought to go from here?"
"That depends a good deal on where you want to get to," said the Cat.
"I don't much care where –" said Alice.
"Then it doesn't matter which way you go," said the Cat.
So, the question is "where do you want to get to."
~Don
~Don
~Don
well, im building some 2-way monitors with an AE td15m and some beyma cp385/ nd compression drivers... the monitors will be active and pretty efficient. i will tune them around 50-55hz. need a sub i can use with them to cover the low-end. i need the sub to play super fast double-kick drum for metal, and play low for ht. i would like this sub to be good for music and ht. is this possible with a th? here's some music i want to replicate well...
YouTube - MESHUGGAH - Bleed tune to 2:39
YouTube - Lamb Of God - Dead Seeds (Drums Only)
tune to 2:06.... also around 3:06 the drummer hits an 8O8... low bass note. i need the sub to cover that aswell.
looking @ ur info,i go for a th .well, im building some 2-way monitors with an AE td15m and some beyma cp385/ nd compression drivers... the monitors will be active and pretty efficient. i will tune them around 50-55hz. need a sub i can use with them to cover the low-end. i need the sub to play super fast double-kick drum for metal, and play low for ht. i would like this sub to be good for music and ht. is this possible with a th? here's some music i want to replicate well...
because you x-over @ 55,you can tune it @ 20 hz no problem,but it needs to be big!
mind that the heavy metal kick drum have also verry high notes that wil be played bij your compression driver!
th vs elemental design A7 - 900? both are beast... very large enclosures. but... the th would cost a lot less for sure. the A7-900 has some awesome reviews. i dont know... just throwing that out there. anybody here ever build a diy A7-900?
Elemental Designs: Car Stereo, Home Speakers, Electronics
http://www.edesignaudio.com/product_info.php?cPath=2_41&products_id=606
Hi nephylum,
According to Elemental Designs specifications the A7-900 comes with a built-in 1300Wrms amplifier, and features two 18" long throw drivers in a 19.45ft^3 (external) cabinet, at a cost of $2,500.--. Which tapped horn are we comparing this too?
Elemental Designs also has the O-Series v.2 driver, model 19O.v2 18" driver available @ $245.-- ea. Maybe you could put this driver into Hornresp, and simulate a BR and a TH and see what you get?
Regards,
Regards,
Hi nephylum,
Regards,
hmmm... that enclosure would be huge if i used the 19O.v2 sub. if i could make it tall, instead of wide like the danley spud... i would definitely do it
Qts: .369
Qes: .37
Qms: 7.5
Fs: 26.00Hz
Re: 3.5
Vas: 228L
Mms: 307.0g
Bl: 22.10T*m
SPL: 90.5dB
Sd: 1200cm²
Xmax: 22.0mm
Voice Coil: 62.5mm
Magnet Width: 8.200"
Cutout Diameter: 16.375"
Mounting Depth: 9.625"
Weight: 42lb
Total Height: 10.600"
Displacement: .10 ft³
Outside Diameter: 18.375"
Qes: .37
Qms: 7.5
Fs: 26.00Hz
Re: 3.5
Vas: 228L
Mms: 307.0g
Bl: 22.10T*m
SPL: 90.5dB
Sd: 1200cm²
Xmax: 22.0mm
Voice Coil: 62.5mm
Weight: 42lb
note i put 2mh of le but you could play with thatQts: .369
Qes: .37
Qms: 7.5
Fs: 26.00Hz
Re: 3.5
Vas: 228L
Mms: 307.0g
Bl: 22.10T*m
SPL: 90.5dB
Sd: 1200cm²
Xmax: 22.0mm
Voice Coil: 62.5mm
Weight: 42lb
hmmm... is that 110 db @ 14hz? hard to read. i need to sabe pic and boost image scale. thanx for the help. how many liters do you think this sub would need?
Hi nephylum,
I use Gadwin PrintScreen, they have a freeware version towards the bottom of that page:
Gadwin Systems, Inc. - Software for your business. DiagramStudio - program for create diagrams and flowcharts; GeForms - solution for design and filling forms, hundreds of free business forms.
As to the tapped horn simulations, you have to decide what you want, just like with other enclosures, there is a great deal of variety of what can be designed. As an expample here are two 500 liter tapped horns with the ED 19Ov2:
Regards,
Regards,
hmmm... how many liters do you think this sub would need?..
Hi nephylum,
495L= ~ 17.5 cu.ft. with an internal length of 505,3 cm or ~16.6 ft that if single folded using 0.75" wood would be ~509 cm or ~ 8.35 ft tall.
See the picture for more important info.
b
how in the hell do you save graphs and stats from hornresp and post the pics here? i cant figure out how to save the image then download to photobucket. how?
I use an old demo version of SnagIt 5.0 which like Gadwin lets you store them in a folder on your computer from which you can then access to attach them to your posts or upload to a web hosting site.
GM
Hi bjorno,
Like always: nice work! I like your comments and hints.
As to the tapped horn: I prefer the 4 section over the 3 section simulation, it makes it a lot easier to level out the peaks and valleys in the passband, also, keeping the L12 dimension as short as possible has a tendency to clean up the impulse response
I don't think that you need much more equalization and filtering with a tapped horn than with any other vented enclosure. This is probably a gross simplification, but they all unload below the passband, and they all have audible artifacts above the passband that should be filtered out. In practice this doesn't seem to be a major problem at home volume levels (below house wrecking).
In the end the room is going to be the real problem.
Regards,
Regards,
- Subwoofers
- tuba vs taphorn?
