TU-8800 available now
0.01 X 2
0.1 X 2
I have Mundorf Supreme Silver Gold oil or Vcap Copper
Also TKD 2CP601S is available for TU-8800
Takman 2% resistor 2nd week of December
Lundhal January 2020
TU-8800 $1185
Takman REX50G 2% Carbon Resistor (85 PCS) $65.00
Mundorf Supreme Silver Gold Oil 0.01 X 2 + 0.1 X 2 $150
Mullard KT88 + Tungsol 12AT7 $125
JJ Tube set $135
JJ KT88 blue + JJ 12AT7 $145
Gold Lion - Matched Pair KT88 X 2 + 12AT7/B739 X 2 $160
TKD 2CP601S $65
● Rated output: 12.5W + 12.5W (KT88-HIGH mode / UL connection THD 10%)
● Rated input: 360mV
● Residual noise: 90μV (IHF-A)
● Frequency characteristics: 12Hz to 55kHz (-3dB)
● Input impedance: 50kΩ
● Output impedance: 4 to 6.3Ω, 8 to 16Ω (switched by the switch on the back)
● Input terminal: LINE x 2 (LINE1, LINE2): RCA jack 3.5mm stereo mini jack (uses both LINE2 and cuts LINE2 when plugged in)
● Output terminal: Speaker output terminal: Gold-plated screw terminal (banana plug can be used) Headphone terminal: 6.3mm headphone jack
● Power supply voltage: AC120 / 200V 50 / 60Hz (3P inlet)
● Power consumption: 95W
● Body dimensions: W350 x H204 x D324mm (including protrusions)
● Body weight: approx. 12kg (without power cord)
