TSSA V1.6 docs and buyers list
Hi all.
The TSSA V1.6 is the final production ready amp.
The component list for the amp is:
http://sitosite.dk/amps/TSSA V1.6 componentlist.xlsx
Schematic for the amp is:
http://sitosite.dk/amps/TSSA-01300712.pdf
The PCB layout as interactive PDF:
http://sitosite.dk/amps/TSSA-01080812-pcb.pdf
The assembly instruction will follow shortly.
I would prefer to deliver the modules with all SMT assemblied on the boards. I have tried to sell boards before without SMT assemblied and people did not get them made...
All buys should be mailed to [email protected]
Sonny
there are a couple of resistors in the BOM named CMF55 with 0,5W... afaik CMF55 has only 0,25W and CMF60 is the equivalent with 0,5W. Is 0,25 sufficent?
Do you have a source for the transistors Q18, Q19?
While KSA1381ESTU is available at Mouser, KSC3503ESTU is stated as discontinued (it is still available in hFE1 D grade, but KSA1381 is only available in E grade...)
Boris
Salas
diyAudio Chief Moderator
2002-10-08 11:31 am
Athens-Greece
If its the Eidolon it took an FM Acoustics prosound genes amp to sing in an installation I did once after it was pushing the owner's Naim Nap 500 to stridency at high SPL times, not an easy speaker at all. TSSA will be great on 93dB+ 4 Ohm or 90dB+ 8 Ohm non quirky Z speakers IMHO.
Sorry to butt in here; but what if the output devices are doubled or single 16Amp 250Watt devices are used? Driver current may need to be increased slightly.
