Tripath TA2022 with single supply
I just purchased some EB-TA2022 boards and I would like some help/suggestions with using them BTL with a single supply.
I have a couple toroids that have dual 42VAC secondaries but the TA2022 can only handle up to +/-35VDC. I would like to put one amp on each of the secondaries in a BTL configuration.
The TA2022 needs a ground reference between the power rails or it won't turn on. I guess my question is what is the best way to do this? I imagine there won't be much current flowing through the ground in BTL.
