Tripath amps and varying speaker impedance
I keep reading little snippets of how Tripath amps with a certain filter type don't cope well with varying speaker impedance. Can anyone elaborate on this and the real world implications? My FR125s speaker impedance appears to rise significantly as it gets near ~ 50hz - is this a problem for these amps?
Maybe I've misunderstood the whole thing - I'm still learning! Cheers 🙂
All drivers have a variable impedance with frequency, not to worry.
Larger issue is that Tripath ceased to exist.. Years! ago.
Current Tripath chips are cheap crappy fakes.. of widely varying 'badness'.
Avoid them, is the short answer.
Huh? Cirrus Logic bought out Tripath. Cirrus Logic is quite capable of making the Tripath chips. I, unfortunately, was a Tripath investor ...sigh...but luckily made it all back (and then some) owning Cirrus Logic (CRUS), no thanks to the Ipad/Iphone/Ipod
https://en.wikipedia.org/wiki/Class_T_amplifier
I was thinking this was the situation when the speaker impedance was designed as part of the output filter for the class-D amplifier; not the impedance vs. frequency of a particular speaker. Or maybe I've misunderstood the whole thing.🙂 I haven't run into any problems using the same amp with 4 or 8 ohm speakers, so differences, if any, are subtle.
Cheers for the replies. I might try a larger Class D amp instead so if it doesn't work on the mains out I can use it for the subs and the effort won't be wasted. The FR125s impedance appears to hit ~40ohms at the low end, if I'm reading the graph right. Maybe that's normal, though.
