Hi
I'm looking for advice on driver selection for a gainclone amp under construction.
The basic configuration is a tri-amped stereo design with 100w bass, 50w mid, 50w tweeter with 3/way active crossover and utilizing lm3886 ic's for output stages. The amp is designed for 8 ohm load, but with paralleled chips on the woofer (thus requiring 4ohm load).
Does anyone have suggestions or criticism on the configuration? Is the balance in output power between woofer mids and tweeters ok?
