I would like to know exactly what "Center Tapped" means with a Transformer?
Example: If you needed to replace a Power Transformer that has only 2 primary wires and only 2 secondary wires; Could you replace it with a "center tapped" model?
Would the "middle, third or center wire be left open in this case? or is it used as a ground? Thanks for any help.
