I have a 500VA Avel toroidal transfo- I wanted to know if its normal to hear a slight hum eminating from it. It is loudest when power is first applied to it and then it decreases but doesnt go away. I disconnected everything from the secondaries such as rectifier boards and it made no difference...Is this normal?
Hi Moze,
Most often, that is perfectly normal. If you leave it hooked up and on, let it run for 1/2 an hour (say). See if it gets hot. Since I can't hear the hum, I can't tell if it is abnormally high. Chances are that everything is perfectly fine.
-Chris
-Chris
