Transformer Distance?
if the toroid powers the amplifier and that in turn drives six speakers, then why do you need to locate the transformer next to any of those six speakers?
Surely you can get 6inches (150mm) gap from transformer to nearest speaker.
........ I was going to place it with 1" gap from each other
Yes I was going to locate the transformer in the bottom of the tower speaker,
have you changed your mind?
Was 1", now in the bottom of.
What is the maximum current flowing from the smoothing capacitors?
What is the resistance of the cables connecting the smoothing capacitance to the amplifier?
Now calculate the maximum voltage drop between the smoothing capacitors and the amplifier.
Is there decoupling fitted to the amplifier to meet transient current demand?
