Transformer Coupled Pentode Question
I am pretty comfortable working with triodes, but other than in guitar amps (where I just do what Leo tells me to do) pentodes remain a bit of a mystery.
So, I have a triode strapped D3a in an amp as shown. This is a really nice headphone amp, but I got to thinking that maybe it would be interesting to experiment with the d3a in pentode mode.
I attached the pentode curves with G2 at 150V. B+ is conveniently at 150V already. So, if I simply disconnect G2 from the plate and instead connect it to B+ right before the output transformer, does this get me pentode mode? From the load line I drew for a 5K load, it looks like I need to lower the bias to ~1.25V with a 33R resistor, but is that all there is to it? Is there a better way to do this? And, what sort of changes should I expect? more power? More distortion? Anything?
Thanks,
dsavitsk said:
...I need to lower the bias to ~1.25V with a 33R resistor, but is that all there is to it? Is there a better way to do this? And, what sort of changes should I expect? more power? More distortion?...
grid current begins at -1,3Volt, so the bias -1,25 ist to small. And for decreasing the autput impedance of the pentod you're needing voltage feedback, this lowers the input impedance (in this schematic).
Regards Andreas
Re: Re: Transformer Coupled Pentode Question
I'm afraid I don't know what either of these mean. How do you know that from the datasheet?
Assuming this means I need some feedback somewhere? I'm afraid I don't even know where to start looking for how to do this ...
