Transfer Function/Room Boost Calculator?
Re: Transfer Function
For now, I'm just looking figure out the boost on frequency independent of room reflections, modes, etc. I realize that this is a simplified account of response, but I want to, at least, take care of this variable. That way I have made the problem of positioning in the room less of a tradeoff between output and smooth response, even though I will not have entirely eliminated the problem.
Am I making any sense?
Dave
The problem is that depending on placement and room shape alone there could be close to no gain, going all the way up to 10-12dB at 20Hz in a very small (car) room.
Room shape is far more important than it's volume. I'm sure someone with more knowledge of room interactions could suggest a room shape with a small volume that offered very little gain, and a room with much larger volume that offered a huge amount of gain.
You could always measure your room's transfer function. Details on how to do this in a car (it should be rather similar in a room) are available at http://www.diysubwoofers.org/projects/cartf/
In my qualitative experience, room gain isn't nearly as high as most suggest it is unless you consider corner placements.
You can measure your transfer function pretty easily using a cheap radio shack SPL meter and an existing sealed driver that is large enough to produce SPLs above ambient in a relatively anechoic enviornment (the middle of your back yard for example?) in the lower frequencies of interest.
jt
jt
That is such a great idea I just tested out my new sealed Tempest subwoofer driven with 500W in my back yard. My neighbours complained so I came inside. It is definitely "above ambient" at 20Hz. 🙂
And it conforms almost exactly to the WinISD simulation. Slightly deeper response, actually. Must be the extra stuffing.
