8 or 4 Ohms.Do you want to know 8 or 4 ohms or do you want impedance plots?
The brochure for these speakers suggests they are 8 Ohms total. But, in my view, they should be 4 Ohms.
So, I ask here for other opinions and also values on each driver.
Do you simulate? Toss in the values with generic 8 ohm drivers and plot them, then add 8 ohm resistors to bring the load to 4 ohms, and see if one looks less likely than the other.
Good idea.Do you simulate? Toss in the values with generic 8 ohm drivers and plot them, then add 8 ohm resistors to bring the load to 4 ohms, and see if one looks less likely than the other.
Thanks very much.
A (preferably true RMS) multimeter, a signal generator, a resistor, a switch and a variable resistor allow you to build a ‘Wien bridge’. That way you can measure your own impedance at various frequencies. I used to do this in the pre-pc era.
Otherwise, just get a dual channel audio interface, some resistors and LIMP (ARTA) to measure yourself with your pc. It’s not really hard to learn. Just my 2 ct.
- Trace back the driver's impedance from the crossover schematic.
