HI all,
can I subsitute tr 2SA1302 + 2SC 3281 with 2SA1493 + 2SC5200
what is the substitute for MJE 15030 and 15031
Many thanks for the reply.
sorry my bad.... the tr should be 2sa1943.
how bout 2sc2922 and 2 sa1216 or its bigger brother (300w device)
can it replace sa1302 and sc3281?
please enlightened me on the secret of tr substitution?
what should I look carefully...
please bear with me....
I'm a diy novice and have about zero know how in circuit designing or trouble shooting
miracoulusly though I've built JLH 15W class A (still some hum issue and oscilation from the psu) and a kit power amp using mj 15003 and mj15004
another question
my next project will be the ESP 60 w ( http://www.sound.au.com/project3a.htm )
if I want to paralleling the o/p tr
should i add the emitter resistor to supply voltage or collector resistor to output ?
Thanks alot for your kind attention
[Edited by dexter on 04-16-2001 at 06:19 PM]
another question
dexter,
yes, but the case is different and the complementary for the 2sa1493 is the 2sc3857 not the 2sc5200.
I don't know about equivalents for the MJE's.
All the transistors you are looking for are available in the US.
There appears to be some finger error here. I assume that the 2SC1493 in the original query should have read 2SC1943. The Toshiba manual specifically quotes the 2SA1943/2SC5200 as direct replacements for the 2SA1302/2SC3281 (the case size is the same - TO3-P(L)).
Geoff
Geoff
The MJE15030/MJE15031 are high power/high frequency driver transistors. Depending upon the application, there are a number of substitutes. Assuming that you are looking for drivers for the 2SA1943/2SC5200 then suitable alternatives would be Toshiba's own drivers, either 2SA1837/2SC4793 or 2SA1930/2SC5171. These have the same case (TO-220) as the MJE devices. The 2SA1930/2SC5171 have a higher current rating (2A) than the 2SA1837/2SC4793 (1A) and are nearer to the rating of the MJE15030/MJE15031 (4A).
Geoff
Geoff
This thread seems to be the appropriate place were to post this link, that maybe is old news:
http://www.pitt.edu/~gszekere/trans.txt
It appears to conver all the basics, too bad there is no Hfe.
