While ordering a sample from Texas Instruments (PGA2310) I noticed a link to the TPA3123 page so after having a glance at the datasheet I decided to order also 3 samples of it to "play" with class-D amp.
Some time later I realized that its package is a HTSSOP24 and for an hobbyst like me who makes PCBs using the "Press & Peel sheet" method, it's probably very difficult to print such SMD footprint.
Anyway, I can solder it since at work I have an hot air solder station.
Does somebody here know where to buy (if available) "bare" board for that IC?
I only found already assembled board.
Thank you, best regards.
Roberto
Roberto
