So I'm building bluetooth speaker box. Just one speaker.
I take my Bluetooth module, use 1k resistors to sum the stereo into mono. Feed that into the single amp channel.
All works great.
Till I turn up the volume past 75% and it goes blahhhh (so to speak).
TPA3118 60-watt mono board:
DC 12V-24V TPA3118 BTL 60W Mono Digital Audio Power Amplifier Board Module M374
LN-BT02 Bluetooth Audio Receiver Module:
http://www.amazon.com/Generic-LN-BT02-Stereo-Bluetooth-Receiver/dp/B0130LL7FM
Here's the scenario just now.
I use my cellphone's bluetooth to send a 200hz test tone to the BT module. Which gives the summed signal to the mono amp. Which feeds a 3.5" NS3 full range speaker.
Sounds great.... until I get to about 3/4 volume when suddenly the tone goes weird, higher pitched sounding. An extremely audible difference in pitch.
So I put my voltmeter on it and at low/mid volume the 12.6V LiPo battery pack (freshly charged) will be at ~12.5V all the way until I get to that barrier where the high pitched sound takes over. And suddenly the battery pack shows ~5V.
Is this a symptom of signal/amplifier clipping?
What can I do to resolve this?
I don't have any AUX wired to the module so the only signal I can send it is from my cellphone.
Hmm, I may try my computer too.
All works great.
