the 2SC5200/2SA1943 are new Toshiba numbers, replacing the old numbers 2SC3281/2SA1302.
My data book says, they have the same characteristics.
So you could try to find the spice models for 2SC3281/2SA1302.
The AKSA FAQ also states that these pairs are identical, and they replaced the 2SC3281/2SA1302 with 2SC5200/2SA1943, when the latter went obsolete:
http://www.printedelectronics.com/faqs/faqs_aksa.html
BTW, these transistors are fine. I am using the 2SC5200/2SA1943 in one of my own designs, too.
regards,
Hartmut
regards,
Hartmut
*2SC3281 MCE 5/13/95
*Si 150W 200V 15A 30MHz pkg:TO-247 2,1,3
.MODEL 2SC3281 NPN(IS=10.000E-15 BF=155.65 VAF=100 IKF=9.2028 XTB=1.5
+ISE=54.325E-15 NE=1.3056 BR=10.787 VAR=100 IKR=1.8561 ISC=106.69E-15
+NC=1.6728 RC=26.745E-3 CJE=2.0000E-12 CJC=534.41E-12
+MJC=.33333 TF=8.0821E-9 XTF=3.1968 VTF=21.461E-3 ITF=169.59 TR=187.91E-9 )
*2SA1302
.MODEL 2SA1302 PNP( IS=21.479E-12 BF=136.48 VAF=100 IKF=19.980 ISE=21.504E-12
+NE=1.3784 BR=329.48 VAR=100 IKR=19.980 ISC=4.3670E-9 NC=1.4264 RC=93.301E-3
+CJE=755.31E-12 MJE=.33333 CJC=1.1417E-9 MJC=.33333 TF=1.2802E-9 XTF=10 VTF=10
+ITF=1 TR=10.000E-9)
*MJL3281A
.MODEL MJL3281A npn
+IS=6.5498e-11 BF=139.247 NF=1.00176 VAF=46.776
+IKF=10 ISE=7.75232e-12 NE=3.34341 BR=4.98985
+NR=1.09511 VAR=4.32026 IKR=4.37516 ISC=3.25e-13
+NC=3.96875 RB=11.988 IRB=0.111742 RBM=0.102914
+RE=0.00127227 RC=0.209833 XTB=0.115253 XTI=1.03146
+EG=1.11986 CJE=1e-07 VJE=0.4 MJE=0.450375
+TF=7.04629e-10 XTF=1000 VTF=2.06045 ITF=41.8156
+CJC=5e-10 VJC=0.4 MJC=0.85 XCJC=0.959922
+FC=0.1 CJS=0 VJS=0.75 MJS=0.5
+TR=1e-07 PTF=0 KF=0 AF=1
*MJL1302A
.MODEL MJL1302A pnp
+IS=3.25053e-12 BF=60.3363 NF=0.992063 VAF=19.8199
+IKF=7.18352 ISE=3.25712e-12 NE=3.42487 BR=5.15499
+NR=1.03617 VAR=2.77936 IKR=9.38159 ISC=2.5e-13
+NC=3.89405 RB=0.776136 IRB=0.0998107 RBM=0.776136
+RE=0.000613663 RC=0.0424163 XTB=1.43773 XTI=1
+EG=1.05 CJE=1.57135e-08 VJE=0.728073 MJE=0.42161
+TF=2.63264e-09 XTF=1000 VTF=4.11586 ITF=266.249
+CJC=1.79861e-09 VJC=0.814822 MJC=0.473271 XCJC=1
+FC=0.8 CJS=0 VJS=0.75 MJS=0.5
*2SA1302
*MJL3281A
.MODEL MJL3281A npn
*MJL1302A
.MODEL MJL1302A pnp
2SC3821 and 2SA1302 spice models
Thanks, boraomega
Running these models. Screenshot:
My spice test show some values that are Not reasonable to me.
At ... COLLECTOR-EMITTER 20 Volt and 1 Ampere:
2SC3281, VBE = 831mV
2SA1302, VBE = 631mV
I also have consulted the Datasheet diagrams concerning Voltage Base-Emitter. I can not find anything confirm such a difference.
I also ckecked out Orcad Spice library, but they use exactly the same model.
Shows that when one 'bad spice model' is around, it may turn up most everywhere. There are several known such cases of not correct models all over!
Here you can find the PDF Datasheets I have consulted:
http://lineupaudio.freehostia.com/pdf/contents.php
Important Note:
Login using password: diyaudio
I have written and setup a script to restrict access. DiyAudio people only!
lineup
hifidaddy said:2SC5200/2SA1943 are new Toshiba numbers, replacing the old numbers 2SC3281/2SA1302.
http://www.aksaonline.com/faqs/faqs_aksa.html#aq15
regards, Hartmut
boraomega said:*2SC3281 MCE 5/13/95
*2SA1302
Thanks, boraomega
Important Note:
lineup
Re: 2SC3821 and 2SA1302 spice models
Any comments and findings on this would be welcome.
I will use these models to Evaluate a Power Amplifier schematic, found in internet.
So, of course, in order to get comparable results (with another known amplifier),
I surely want only as good Spice Models as possible:
2SC3281, 2SA1302
... who are said ( by Hugh 'AKSA' Dean ) to be comparable to
This Very Popular Output stage complementary pair:
2SC5200, 2SA1943
Lineup
hey!lineup said:My spice test show some values that are Not reasonable to me.
Important Note:
2SC3281, 2SA1302
2SC5200, 2SA1943
Hello everybody,
I am looking for the schematic diagram for 2SC5200/2Sa1943 and they go with C2705/A1145.
Thank you so much!
No you are looking for the schematic of an amp! There is no 'schematic for 2SC5200/2Sa1943 and they go with C2705/A1145'. Those transistors are in an amp, and if you want to know how to use these transistors that depends on the amp schematic.
Please give type/brand etc of the amp....
jd
Search on the forums here - I seem to remember that Andy_C has posted more accurate model(s) of the MJL1302/3281 that take care of some inaccuracies in the published OnSemi models.
Yea, his models are very good. He published models for 2sc4793/2sa1893 and 2sk1530/2sj201 transistors, also. Too bad he is banned from this forum, he is a great contributor and a very helpful person.
Fairchild has models on their website for their FJL4215/4315 transistors IIRC. These may be usable models for the Toshiba's.
>>[Andy_c] published models for 2sc4793/2sa1893 and 2sk1530/2sj201 transistors, also.
His website only offers the MJL3281/1302 set, unless I'm missing them.
..Todd
..Todd
Here is the answer to the question
.MODEL 2SA1943 PNP (
+ IS=1.30E-10 BF=91.42 VAF=100 IKF=4.480 ISE=1.02E-10 NE=2.0 VAR=100 ISC=5.0900E-9 NC=1.5 BR=0.882 IKR=2.9015 RE=0.0011
+ RC=0.0553 RB=140.05 RBM=0.0041 IRB=8.5e-9 CJE=2.00E-10 FC=0.5 CJC=9.45E-10 VJC=0.48 MJC=0.28 TF=9.250E-10 XTF=10 VTF=10
+ ITF=1 TR=1.00E-8 EG=0.76 XTB=2.68 mfg=Toshiba)
.MODEL 2SC5200 NPN (
+ IS=3.0463E-11 BF=96.20 VAF=100 IKF=15.04256 ISE=5.6190E-11 NE=2.0 BR=4.849 IKR=1.05012 VAR=100 ISC=7.18E-8 NC=1.5 RE=0.0025
+ RB=20.18 RBM=0.0014 IRB=1.0E-7 RC=0.01137 CJE=4.5000E-10 CJC=8.4915E-10 VJC=0.68977 MJC=0.54081 TF=6.8583E-10
+ XTF=9.5721 VTF=10.425 ITF=6.8697E-2 TR=1.000E-8 XTB=1.45 EG=0.82 FC=0.5 mfg=Toshiba)
Can anyone here tell me how to get subcircuit models to work using Notepad?
In LTspice, it is easier if you create a new symbol to go with the subcircuit model, e.g. for MOSFETs. The important thing is to get the order of the pins of the component right.
Your question covers a lot of ground. If you can be more specific about what you want to do, I'll try to help.
In the meantime, here is an example of a symbol and its subcircuit. To use, take off the .txt file extension, copy the .sub file into "C:\Program Files\LTC\LTspiceIV\lib\sub" and the .asy file into "C:\Program Files\LTC\LTspiceIV\lib\sym"
- Toshiba 2SC5200/2SA1943 Spice Models
