WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
Rooting through the storeroom today produced a toroidal 20-0-20-0 PSU, which when metered across the mains inputs (115-0-115-0 wired for 230V), yields 7.2H.
Anyone else done similar, and if so, did you just insulate the original taps?
Toroids have very limited tolerance for dc on their windings, likely if you use it as a choke the core will saturate and you will be left with just the winding dc resistance. Not recommended.
I have tested a transformer as a choke and a toriod autoformer
as a choke in a choke input power supply. I Iloaded them to ~80% of there ac current rating with darn good results.
I think my results were about 5% different than calculated using
Duncan's power suply designer. Now this may not work in all cases but in the 2 cases I tried it sure did.
