I just picked up some surplus 550va toroids for a future Aleph project. They have 4 leads coming out of them, where as others have 6 leads. Is this still OK for such a project??
TIA
TIA
Does anyone know an online source for surplus transformers I could use for an aleph? I've been very hard pressed to find any. I would be more than happy to use a couple for each amp if necessary. I'm building either an Aleph 4 or a pair of Aleph 2's. Thanks.
Rob
Rob
Rob,
Hope this helps.....
http://www.apexjr.com/miscellaneous.html
Also you might want to take a look at this link....the info might help..
http://www.diyaudio.com/forums/showthread.php?threadid=1088
Thanks for the links. Do you know if the 1010VA transformer on the apex jr. page would work to create the +/- 48 Volts of the Aleph 4 or the +/- 45 Volts of the Aleph 2?
