A new approach to reducing tube microphony! The Top Hat is machined from a slug of high density metal, into a unique and novel shape. The Top Hat, when attached to a small-signal tube (ie. 9-pin), is designed to lower internal microphonics, and to lower the tube's suseptibility to microphonics induced from external sources. The Top Hat is glued to the top of the tube, using an easily removable adhesive. This allows the top hat to be re-used almost indefinitely. The Top Hat tube dampers and container of adhesive. Reg $129.00, Sell$50.00
Bought for my tube phono stage, but abandoned the project.
