SOLD!
I'm trying to clear out some parts and downsize in preparation for a move. I have on offer one "box 'o ICs". This contains lots of op-amp and signal processing circuits, some class-AB chip amps, plus a component tester, dip sockets, etc. It's all in a large shoe-box that I will repack for shipping. There is an approximate inventory below but I did not count up parts so I cannot guarantee quantities, etc.
I would like to just ship all of this to a single buyer, US only.
Asking $60 with shipping included. Please PM me if interested.
QTY | Description |
30 | MC78M12CT 12V fixed voltage regulator |
20 | NE556N dual timer IC |
100 | LM555CN timer IC |
3 | LME49740 quad audio op-amp IC |
10 | LME49720 dual audio op-amp IC |
17 | LF353 dual op amp IC |
100 | NE5532 (Texas Instruments) dual op amp IC |
5 | MC33274 quad op amp IC |
20 | TL074BC quad op amp |
100 | LM358 dual op amp |
10 | LM317L adjustable positive voltage regulator, TO-92 case |
14 | LM317 adjustable positive voltage regulator, TO-220 |
14 | LM337 adjustable negative voltage regulator, TO-220 case |
25 | 2N4401 600mA 60V NPN transistor |
2 | INA134 differential line receiver |
2 | OPA2132 dual op-amp |
2 | LTC1062 5th order low-pass switched capacitor filter |
24 | TDA7293 |
10 | SSM2018T VCA |
4 | SSM2164 quad VCA |
32 | NE5532 op amps (Fairchild) |
56 | UAF42 second order active crossover IC |
4 | LM7805 5V regulator |
4 | MCP130-475DI/TO supervisory circuit - reset at power on |
4 | 4017 decade counter (HCF4017) |
4 | 4093 quad Schmitt trigger (CD4093) |
4 | 4510 BCD up/down counter |
4 | SN74HCT251N 8-1 multiplexer (HCU) |
74HC251 8-1 multiplexer (HC) | |
4 | 74HCT04 hex inverter |
12 | 74HCU04 hex inverter w/unbuffered outputs. “the XX74HCUXXXXX, consists of single-stage unbuffered CMOS compatible devices for application in RC or crystal controlled oscillators and other types of feedback circuits which operate in the linear mode” |
10 | LT1054 switched capacitor DC voltage doubler/inverter |
25 | MC33201 rail-to-rail single supply op-amp (single amp, DIP-8) |
25 | OP-07D low-offset low-noise single op-amp |
2 | OP-275GPZ JFET dual audio op-amp |
2 | OP-482 quad op-amp |
3 | SI8602AC-B-IS I2C isolator |
Hi
I cannot see the option to PM you, maybe I do not have that option yet, anyway I would like to take them if they are available.
thanks
thanks
