Hello all,
Advice needed...
I'm about to start building my Alephs (possibly XA's but haven't decided yet). This weekend, I was thinking through the design and the idea came about to build a pair of stereo amps rather than a pair of large monoblocks... Essentially instead of a pair of 1.2's, I'm considering a pair of stereo 2's...
Yes, the heat - but I believe I've got that handled... Water-cooled is the current direction...
So my question is which is the better solution sonically? Biamp using a very high quality active crossover or a pair of large monoblocks biwired to the speakers???? I've always figured that eliminating the passive crossover components in the speakers would be a good idea but so far the electronic crossovers that I've heard have a far worse signature... I've tried most of the crossovers that are available and have currently settled on a pair of Bryston 10B L/R's as the best option that I have found from a sonic standpoint... They are fully discrete, balanced and 24 db/octave using very high quality components. Unfortunately, I can still hear them so I keep going back to the no active crossover option... The next attempt is to try high quality passive components between the amp and the preamp matched to the input impedance of the amp...
System presently consists of Apogee Studio Grands, Threshold Ta-300 (converted to a SA 3.9), Melos SHA Gold preamp, Pioneer DVL-91 Laserdisc player as CD transport and California Audio Labs Alpha 24/96 tube DAC, and lastly Goertz MI2 speaker wire and with home made interconnects using Canary star-quad wire.
Yes Nelson, I would love to try one of your new crossovers but it will take a while...
So, if you were considering building a new pair of monoblocks and the cost of implementing them as a pair if stereo amps vs. monoblocks wasn't the primary issue, what would you do????
Lastly, the Apogee's resolve to an extent that I can easily hear an interconnect change so please keep this in mind when thinking of adding another component to the signal chain...
Thoughts????
Thanks very much!
Steve
PS - Just so you also know the upgrade plan - amps first, preamp (Aleph P or X), new TT with Pearl or Ono, then new CD player and/or DAC...
Advice needed...
Thoughts????
Thanks very much!
Steve
