In power amps, from memory, I've only ever seen TO-3 power transistors orientated with the 'top hat' section upwards when horizontally mounted on heat sinks.
I assume there wouldn't be a problem mounting them 'upside down' with the terminals at the top?
The reason for doing so is that I need more clearance between the connecting leads and the amp boards themselves.
So I thought it better that I should ask before trying.
