Thumbs up for Neutrik Profi RCA connectors
Joined 2021
Used these for my first cable building project. The probably 20+ year old monster cables were getting pretty loose. They are expensive but well made and really grab onto the socket. If you trip on these things, you’re probably taking down whatever component you have them attached to.
Reactions: 1 user
I quite like them. I have tried a lot of RCA connectors, from very cheap to very expensive, and these are my favorite. I find them easy to solder to, and they accept large diameter cable. Most cheap RCAs are flimsy and can’t handle big cable, and expensive RCAs have no dedicated affordable for soldering the ground wire, leaving you to mush it onto the smooth sides somehow.
