Through holes - double side
I'm short of ideas today.
Do you know how to make (at home) something similar to those beautiful plated vias for double sided pcb's?
I can make my own two sided pcb's but when caps (or other components) are to be soldered, you can't solder on top. No problem with the resistors tough.
Re: Hello RAka try this link:
mwmkravchenko said:
http://www.mouser.com/catalog/623/1286.pdf
They are called wide rol eyelets. And there is a staking tool set below them. It helps to press them onto the PCB evenly.
MArk
Those rivets might be a good item for DIY tube socket on a PCB. No more hunting around for 7 and 9 pin miniatures, novars and octals (to say the least of Nuvistors!).
Jack
