This loudspeaker how much dB increase
Two correlated sound sources (i.e. they reproduce exactly the same signal) give a doubling of the sound pressure which is a quadrupling of sound power i.e. 6 dB increase. This is of course a theoretical ideal and it will be lower in practice.
If you use two uncorrelated sound sources with the same acoustic power then the sound power is doubled, giving an increase of 3 dB.
Charles
to help avoid confusion, I'd suggest you separate the power changes from the efficiency changes when you couple speakers.
The efficiency changes come with very restrictive conditions. You can get +3dB with each doubling of the numbers of drivers, but only over a very restricted frequency range.
If you feed the same power into one speaker as you feed into a multiplicity of speakers then one does not get any extra power input.
If spreading the same input power between a multitude of speakers helps avoid power compression then that is the gain one can get from adding drivers.
Regards Charles
So it is 12dB (theoritically) for 4 drivers as you have said earlier. Thanks for the information .
How can we judge this frequency range(where doubling occurs) is this found emperically.
I have a further worry as it can be seen the drivers are placed side by side (above attached speaker picture) therefore the direction of wavefront will be facing each other , can this cause a heating or distortion , as I can visualize that the two wavefronts are a kind of colliding with each other in opposite direction.
Thanks for the inputs
