Thiel CS3 - a drop in replacement tweeter for Dynaudio D-28 AF?
Hello
Is anyone familiar what would be the best (or reasonable) drop-in replacement for Dynaudio D-28 AF tweeter (both crossover and mount wise) in Thiel CS3 (Serial Number 1736)
Also (apart from mount) would non-AF D-28 work?
Thanks!
Hi anu,
Can't you find the original Dynaudio D-28 AF tweeter?! Are they beyond repair?
In case you need references the Eton 25SD-1, 1" Soft Dome, is a direct replacement. Be aware, I would be suspicious without experiencing or first testing. The Dynaudio is a 28mm soft dome. The Eton is a 25mm. That shouldn't be a problem for a 3 way, plus different Fs wouldn't make here a big part.
http://www.gattiweb.com/images/dynaudio/d28af_data.pdf
http://www.etongmbh.de/uploads/tx_pbproducts/25SD1_01.pdf
They have the same faceplate 110 mm.
Screws will need new pilot holes 3 vs. 4.
Thiel CS3 loudspeaker | Stereophile.com
Altoparlanti di Ricambio - Audiokit E-commerce - Vendita componenti
(Recommended by Madisound)
The Madisound Speaker Store
Eton, 25SD-1
Thiel CS2 needs new tweeter - AudioKarma.org Home Audio Stereo Discussion Forums
Thiel 3.6 - Dead Tweeter? - AudioKarma.org Home Audio Stereo Discussion Forums
If they are a little hotter that shouldn't constitute of a problem, the opposite is true. A small calibrated resistor (matched pair) in series will take care of it.
Have fun.
