Hi, does anyone know where can find the Thiel CS2.2 loudspeaker drivers replacement? I got a pair of Thiel CD2.2 and recently found that both left and right woofers are damaged and the Tweeter 1 side is dented due to someone pressed it, now thinking to replace a new set of driver! Btw, do I need to recondition the crossover like changing the capacitors, resistors because this speaker age is more than 20 years already!
The dent MIGHT be fixable with a vacuum cleaner, or you'll ruin it. Only one way to find out.
Resistors may last forever, but you can always upgrade them.
Any electrolytic caps should be replaced. If you want to see about upgrading parts, check what was inside first. Then read here to start.
As for the rest of the caps, if ever a speaker brand needed a Mundorf MKP it's these. They will warm up and smooth the treble. Of course, there are many Thiel fans here who will call this heresy, but that's how I hear them. After looking at the Stereophile charts and the constantly rising treble from 1kHz onwards though I'm not sure this would help enough. I'm not usually a big fan of Stereophile but in this case JAs comments at the end of the measurements section is only a little charitable.
The point being, at best, MKP's would be the right direction vs. more revealing and brighter sounding caps. Personally I'd look for an opportunity to actually modify the crossover and point that treble down, not up. An alternative is the Clarity ESA's which may be even a bit darker.
Best,
Erik
Best,
Erik
Thiel CS2 2 loudspeaker | Stereophile.com
The bass units were often high Qms 4 ohm SEAS drivers. Quite exotic.
http://www.diyaudio.com/forums/multi-way/147632-classic-monitor-designs-17.html#post4358469
You should measure your existing units. Paper? It oughtn't to be too hard to find something similar. Don't forget the old trick of rotating old bass units 90 degrees to reduce voicecoil sag and rubbing.
