The sound of Tantalum?
I've been serching here and googleing without success.
What do tants actually sound like compared to (say) polyester? The active electronics in my active bass guitar used them like decoupling caps between the magnetic pickups and FETs, and between peizo pickups and JFETs, but nowhere else.
I beleive what you mean is that lower distortion Al electro caps give "a degraded sound effect"
tantalum caps distort more than Al electros, higher V rating and nonpolar construction give lower measured distortion with Al electros
Hi Peter,
Ever try some good normal electrolytics? Anything in the 3u3 range and down I tend to use film caps for. I've found that bypassing th elarge 220 ~ 470 uF caps with a 1 uF film helps a lot. Using a 50V electrolytic (or higher - like 63V) is better as well. You can actually measure the dissipation going down as the voltage rating goes up. They typically go up in steps.
-Chris
Interestingly Tantal Elcaps rise so much controvery still: Most engineers and DIYers rate them too low to be even mentioned, others juse them with great success.
Even in the new NAIM preamps and their flagship CD Player the sound is coupled via several (!) tantal caps (the classical blue, whatever brand). Needless to say, that these items sound very good. I have used tantals in most of my preamps since long.
Tantals - as all polar electrolytics - have to have a polarisation voltage to work properly, but then - and only then - can outperform film caps. These are mostly better in bias free settings.
But sometimes - like other elcaps - they get "old" and electically slightly "leaky" , and have to be replaced. I have yet found no trick or recipy to select them for good sound and long life, charges of the same brand are so different.
"""The name "Tantalus" is the origin of the English word "tantalize". The idea is being that when a person tantalizes someone else, that person is making them like Tantalus: there is something desirable that is always just out of that person's reach."""
(from Wikipedia) 😀
Hi , i changed lots of Tants , especially red/blue drops , because of hashness and ... shortages . The only desirable ones are the Milspec CTS13 useful in decoupling . I sold my last ones on Ebay last year . Film is far better in coupling , imho
