2) The -3db point of a simple one capacitor high pass filter.
Many cheap boxes come with a midrange/woofer driver and a tweeter and one capacitor, usually 4.7uf, wired in series with the tweeter. This is a high pass filter designed to pass frequencies to the tweeter and keep low frequencies away from it, where they would do damage.
To calculate the xo frequency of this "crossover", which is a modified 1st Order Butterworth minus the coil, you need this:
The DC measured impedance in ohms of the two speakers
The value of the capacitor.
The desired xo frequency point for -3db.
You can use this formula for 1st order BW and ignore the coil value:
2-Way Crossover Designer / Calculator
Or you can use this:
f = 1 / [2πCR]
f is the crossover frequency in hertz where the two curves meet at the -3db point.
π is pi, 3.14159
C is the value of the capacitor in FARADS. A 4.7uf capacitor would be .0000047 farads.
R is the impedance in ohms of the tweeter, not the other driver. Measure using your multimeter. This is the DC measurement and not the impedance curve, but it will suffice.
If you had a tweeter that was 8 ohms and a 10uf capacitor the crossover frequency would be:
f = 1 / [2πCR]
f = 1 / [2 * 3.14159 * .00001 * 8]
f = 1989 hz
Which is rather low for a tweeter xo point.
To raise this number to 2500 or 3000, more appropriate, you would need a smalerl ohms impedance for the tweeter driver and/or a smaller value capacitor.
