The most efficient 8 inch driver in the world?
Because i have a hi eff DIY dipole and the 8 inch midrange from 300-3000 Hz is the bottleneck.
AELO15 woofers are around 99 dB (16+16 ohm) or even more with parallell voice coils. Radian 475pb-Be CD in Tractrix 1000 Ca 110 dB and finally JBL 2119 8 inch midbass/midrange max 97 dB.
Wizzercone is no problem.
Check out the Jantzen JA8008. New version called JA8008-HMQ. It is a solid 95dB sensitivity, and it sounds very nice. Thin paper cone, so it will have more comparatively 3rd order distortion as the SPL rises than speakers with stiffer or better damped cones.
http://www.troelsgravesen.dk/JA8008-HMQ.htm
Another good one is B&C 8NDL51. Well damped heavier cone, but it makes SPL the old fashioned way with powerful motor.
THX for all the suggestions.
All the mentioned drivers have more or less bader specs than JBL2119 with real 97 dB.
We have measured 2119 with f ex Fostex FE203En-S ltd edition who claims that it have 99 dB. In fact they have the same sensitivity but JBL 2119 dont need corrections. FE203En-S is a little bit uneven in the response.
My open baffel have a modular insert for the satelite: HELOB The Final, en åpen baffel byggetråd
Whit this consept i made CNC inside-baffles for SEAS, Lowther, Fostex both with and without opening for supertweeter, f eks Fostex T500. I also have inside-baffles wihout cutout for alternative future midrange/fullrange drivers.
I have tested following drivers in addition to Fostex FE203En-S and JBL2119:
Lowther PM6A, fantastic driver, ca 93 dB real
SEAS Exotic, ca 93 dB real, smooth but a little bit "dull"
JBL2118, very good but need a small notch compared with 2119 who have very even FR.
JBL is never bragging specs, the are often very correct.
In a mockup we also measured Fane Studio 8: Fane Studio 8M luidspreker - Synthforum who claims 103 dB!!! That ist NOT correct. It is quite equal JBL2119. Fane have a ugly breakup.
The only suggestion i think is significant more effecient than JBL2119 is the AER driver.
One alternative i wonder if could work is TAD1201. Then i have to move the little Tractrix 1000 horn with the 1 inch Radian 475pb-be over the baffle but what about the distance between them. Another issue is the crossover frequency, i think the minimum for the tweeter here is 2500 hz?
TAD TM-1201
