With some delay because of repair of several Luxman amplifiers a.m., the Mitronic PA100 is ready for the complete measuring test.
The first data from the Mitronic PA100 at only +-30Vdc and 50mA pr. output device:
https://picasaweb.google.com/vbkolse...96040978440882
MITRONIC PA100 and the first measurement data:
The plus / minus 30 Vdc and 50 mA for each output transistor revealed the following data:
At 100kHz / 1 Watt output power was the PA100 amplifier - 0.1 dB down.
At 250kHz / 1 Watt output power was the PA100 amplifier - 1.0 dB down.
There could not be measured higher in frequency as the built-in RC circuits 10R / 47N in the amplifier limited the measurement.
By only + - 30Vdc and an output power of 1 Watt, and from 20 Hz to 20 kHz on the HP distortion analyzer, the overall distortion was below 0.02%.
Quite good of the design from 1982.
At full voltage of about +-60Vdc will the amplifier undoubtedly provide other measurement data.
https://picasaweb.google.com/vbkolse...97038376433890
MITRONIC PA100.
All transistors measured after Hfe, amplification:
Right channel: 2SA970 BL Hfe: 296, 296, 295
BF760 Hfe: 116
BF757 Hfe: 120/120
Hitachi 2SJ50: 1,151V, 1,141V.
Hitachi 2SK135: 0.943V , 0,939V.
Right channel DC offset: <0.507 mV DC
The incredibly low DC offset is a result of the measured transistors.
https://picasaweb.google.com/vbkolse...97619801908146
MITRONIC PA100.
Left channel: 2SA970 BL Hfe: 301, 302, 299
BF760 Hfe: 117
BF757 Hfe: 121/116
Hitachi 2SJ50: 1,341 V, 1,340 V
Hitachi 2SK135: 1,044 V, 1,040 V
Left channel DC offset: <4,502 mV DC
The incredibly low DC offset is a result of the measured transistors. The left channel DC offset however, is approx. 4mV higher than the Right channel, but still very low.
Overall view of the Mitronic PA100:
https://picasaweb.google.com/vbkolsen/MitronicPA100#
This MITRONIC PA100 amplifier circuit seems to work nicely. It is difficult to spot any shortcomings in the first measurement tests , I would say
......but more to come.....
http://www.tubeamp.hobbysider.dk
MITRONIC PA100.
BF760 Hfe: 116
BF757 Hfe: 120/120
MITRONIC PA100.
BF760 Hfe: 117
BF757 Hfe: 121/116
