So this is probably not New in Any way, but at least its not used in Any designs I have seen.
Goal is to make a port with a Nice big flare and have control over all dimensions.
The example here is 32cm long and 200cm2 at the end and 50cm2 in the middle. It can be simmed in hornresp as a horn.
The cavity is used to make room for a classic handle cutout.
First test says it works and no farting noise with 12" woofer at 250w.
What do you think?
Kind regards TroelsM
What do you think?
