Once more i find my self tredding along the long path of audio engineering when anougher set of awkard questions are found buzzing about inside my head that demand attention from the masses.
First the question :-
Does vanishingly small amounts of THD in an amplifier GUARANTEE good sound and fine music reproduction?
Explanation :-
I've been developing a classA amplifier for a while and its been on the test bench for far too long now. The problem is i want it to be my best work to date but i'm convincing myself that it dosn't sound that good. A few weeks ago after the project stalled i thought its about time i did some serious research so i started reading loads of papers about the subject of distortion and its effects. I also bought a copy of Selfs 'Audio Power Amplifier Design Handbook'. After reading the book cover to cover i decided to apply some of Selfs methods for reducing THD across the entire amplifier design. After doing this on the sim my amp went from approx 0.065% / 0.016 THD 50/1 Watt to 0.002 / unmeasurable ( < 0.000 ). I was impressed by this figure ( Well done Self ) and so spent this easter mirroring the improvments in the real world on the test bench amp. Upon power up i started to make measurments. Everything seemed good, no measurable THD on the computer via RMMA ( crap soundcard but it said the previous attempt was not that good lol ), good squares and sines on the scope with no noise, 20v/us rise and fall etc. I am convinced there has been a dramatic improvment just as the sim said there would be. I then swapped test gear for audio gear and had a listen. The thing is, i expected the sound to be crystal clear, much improved on the last time i listened but i was dumbfounded to hear it had hardly changed ( if at all ). Hence the question above, if an amplifier has very low THD then why does it not sound as good as amplifiers i have thrown together in the past that use voltage regulators as current sources and have relativly high THD's? Am i imagining this? Are there other hidden distortion's / imperfections that can have a large impact on the perception of sound?? I'm confused but these questions need answers if i'm to carry on my journey into sound.
Thanks for reading
Leigh
Explanation :-
Thanks for reading
Leigh
