testing voltage on tube filament, without the tube
spartan
2010-04-05 8:56 am
I would like to adjust the tube heater voltage without using the tube. The tube rating is 5V/2A. I believe I can use a resistor in its place with the same effect, but I have never tried. Can someone confirm what should be the resistor's resistance and power rating? And if this is a good method?
Thanks!
