Is there any test points in Aleph P1.7 circuit? I found it distorting a little bit in one channel. I want to find a solution!
I'm confused with voltage measurments on the output coupling caps. I have measured 29VDC and 61VAC on all of them. Where is the problem, why do I have both DC and AC?
Compare the Drain voltages and power supply voltages
in the channel that works and the channel that doesn't.
