Tenma 10A Variacs, cheap. As seen in the pics, the plastic bulkheads holding the meter, fuse and recepticle are cracked. They both work fine otherwise, just tested. Nothing a little duct tape can't fix
this is DIY.........
Output is 0-130V
If duct tape and/or glue is not your thing then.......
As a 20 minute project, I would remove the bulkhead, mount to a small piece of plywood, and wire to a household receptacle in a metal J-Box. The wires are connected to the meter, etc with faston terminals, so easy mod.
These sell for $80-$100 new on the web
Two available $25 each + shipping from So Cal
Output is 0-130V
