Hi, I have a Technics SUV-4X that I have had since new in 1984. It has begun intermittently shutting down to safety mode. Sometimes it runs for a few hours, other times a few seconds.
I have replaced Q501-504 but still the same. Also checked over the main board for dry joints. All psu voltages look to be correct and stable as far as I can tell.
Does anyone have any suggestions as to how I can tell if it is the dreaded SVI2004A that is dying?
I'd hate to pension the amp off - I love it and I have yet to find a modern amp that sounds anything like it. Latest audition was Arcam A70 which sounded like the bass rolled off below about 500Hz!
Any suggestions welcome.
Cheers.
Cheers.
There is a way to id the fault.
check that pins 3 and 14 are 0V
then check pins 7 and 10 should be near -rail voltage
- i have a V4X of mine doin this to me at the moment, its getting DC offset on both channels (bout 2 - 4V) - hard to trace at the moment but definately toward the front end i suspect an elusive dry joint on the front end earthing strap.
definately not the SVI
Technics SU-V4X
Hi, it sounds like I have the same fault with my original SU-V4X as you described in your post and I wondered if your request for suggestions earlier this year provided you with an answer that resolved the problem?
Any help would be much appreciated.
Thanks.
Thanks.
Hi, thanks for the reply.
I have a couple of these amps now and I have temporarily left the one that is cutting out to one side as I don;t have much time at the moment. Hopefully soon....
From memory, 3 and 14 are at 0v with a slight rise (80mv and noisy on the scope) to pin 3 when the fault appears. Everything else seems to stay as was when no fault, so possibly a fault further back as you suggest. If I get a chance I'll run it up and let you know what I find.
I have a second one with a slightly distorted left cd input. Only shows up on vocal harmonies, like on the first track of not too late by Norah jones - very selective and specific fault! I switched to the tape input which was fine but 6 months later that now seems to be doing the same. I think it is probably the input switch chip. Nothing to do with the switch to safety though!
I have a SU-V2 that has the problem of cutting out when using a certain input. I also now use TAPE instead of AUX. Seems to be a selector switch problem. The selector switch is a specialised design. Anyone know if a replacement is available?
For the record, believe I have just fixed one of these, replaced the Vas transistor Q502 with 2SA1208 as it is what I had. Old one seemed to be going open circuit and putting amp into protection. Worse on the hi Z option.
I had one channel cutting out from time to time in an SUv4x - especially when cold. Spent ages finding the fault including resoldering lots of joints and replacing the relay. In the end it was a dry joint on the speaker terminal. All good now!
Old thread but may help somebody.
- Chip Amps
- Technics SU-V4X Dead?
