As built by VTA, my M-125 mono-blocks were very noisy, ≈55db unweighted.
After fixing build and design errors, the amps quietened almost 40db to ≈93db unweighted.
I suspect many DIY and retro designs may suffer similar problems.
In an effort to help others with similar problems, complete instructions:
ieLogical VTA M-125
ieLogical VTA M-125
Off topic maybe but I had to share this. Years ago I purchased a driver board kit for one of my Dynaco stereo 70's from them and put it together and it worked fine with the exception that someone didn't do their homework when it came to calculating the wattage of a few resistors. These particular resistors were running at max current. I first noticed they changed color a little which was enough for me to take readings and do the math. I haven't purchased a thing from them sense and when I mentioned the problem on their forum I was banned.
Thanks IEales.
I usually visit the your site and have been emails couple times for questions. Can you add the "Update date" on top of the page whenever there is new mods or tweeting on this amp.
Yours has auto-bias pbc, what is the different without it?
In your modification schematic, what are the value of W and V for resistor and cap? Do you have part# of bridge rectifier or can 1N4007 be used? Can I apply this ground house to other amps as well?
The page : ieLogical VTA M-125 is broken, it only shows top part and no working links( using firefox / Macos )Thanks IEales.
Done. Click to jump to the relevant section.
Without it, bias drifts continuously with varying line voltage and amp temperature. With it, bias is rock solid and monitored so any failure is immediately indicated, although almost impossible to see in the M-125. All tubes are always the same value and easily adjustable to other values.Yours has auto-bias pbc, what is the different without it?
For the Loop Breaker? Links to the parts are in ieLogical VTA M-125In your modification schematic, what are the value of W and V for resistor and cap?
2x 50A diode bridge
10 Ohm 5W-Resistor WireWound
10uF 400V
NO!!! A 1N4007 is 1A. You must be able to conduct the ENTIRE A/C line current to ensure the breaker trips.can 1N4007 be used?
Provided you FULLY understand what you are doing. If you are not well skilled in tube amps, you could create something LETHAL!!Can I apply this ground house to other amps as well?
I'm sorry but I don't have a mac or Firefox. ieLogical is not a commercial site, but it is plain HTML with a bit of php and javascript. In 10 years, this is the first time anyone has said there is a problem. If you PM with an image of what you can see, I could have a look.
I'm retired and only test on the Windows version I'm running on Edge & Chrome, now basically the same thing.
I quit commercial web development in the late 90s when there were 27 flavors of Windows OS and browser versions, plus Linux, apple, Netscape, etc.
When the browser checks exceeded the markup, I knew it was time to move on.
Never regretted it.
Thank you so much for info.
petertub, I have no problem with website since I am in US and using Chrome. Do not use IE 11.xx because it's no longer support.
lab on the cheap
test results on the M-125 with admittedly tinker toy tools from August 2020: lab on the cheap
"If it measures good and sounds bad, it is bad. If it sounds good and measures bad, you've measured the wrong thing." –– Daniel R. von Recklinghausen, HHScott
The M-125's sound G R E A T !!
Built properly, they are an incredibly good value.
Found a solution; if i browse in fullscreen a second scrollbar appears. The web editor obviously assumes things about screen size ( error !)I'm sorry but I don't have a mac or Firefox. ieLogical is not a commercial site, but it is plain HTML with a bit of php and javascript. In 10 years, this is the first time anyone has said there is a problem. If you PM with an image of what you can see, I could have a look.
Never regretted it.
Thanks for the write-up. Good reading.
A scroll bar appears on the bottom if the browser is narrow. One of my ToDo's is make ieLogical more mobile friendly. That won't help with a narrow browser as the check is screen width, not browser.
petertub, I see what you mean. It's a 2 column frames configuration. IEales can set the width in the css of the left frame with a specific pixels then the text wouldn't overlap the right frame when someone tries to resize the screen.
Ahhh.
Post # 1 looks like B+ Capacitor input filters, combined with poor attention to B+ ground loops.
Generally, solid state rectifiers make the supply stiffer, and also generally increase the amplitude of the transient current.
And of course, those B+ secondary current transients can also appear on the filament secondaries too.
Interference on the filament wiring to anything other than an output tube can also cause trouble.
I love Choke Input B+ filters.
I use them whenever possible, especially since I use solid state diode rectification.
Does anybody want to take a guess why I love choke input B+ filters?
Any changes I need to make to my vta 120 I just bought and finished building myself. I did not purchase the autobias board.
ST-120 Improvements
IF my factory built M-125s worked and were quiet, I would have just plugged them in and enjoyed them.
There are some common issues:
I'm a firm believe in if it ain't broke, don't fix it.
OTOH, I love making things the best they can be.
After a lifetime in electronics, I had the knowledge and skill, albeit a bit rusty, to right the wrongs.
Would I recommend reworking a quiet, functional ST-120?
NO
- Smallish main capacitance SCM
- 16Ω tap feedback
- output fault OPT protection
- chassis as earth safety and 0vA
- multi point 0vA
- bias noise
- pent/triode mode
- unstable LM-334
- under rated driver electrolytics
- A/C power wire run with DC
- general wire layout
NO
- Tubes / Valves
- teaching VTA M-125 to sing
