I have a Teac CD-P3450SE with the following fault:
it powers up fine and if you track skip you can hear the laser moving. BUT it will not spin the CD, when you load the CD it is raised by the trasport off the tray and given a little 'kick' as if its starting to spin but then doesn't spin and the display just reads 'disc' (I don't have a manual but presume this means it isn't detecting the disc in the player).
any advice on what I can do?
