Hi, I dunno if anyone can help me. I'm planning on building a TDA2030A chip amp, using 2n3055 + MJ2955 transistor pairs, similar to the one in the datasheet, just using different transistors to them.
First of all, to me it looks like it will work, any objections? If it is an issue please explain why.
Also I plan on putting the transistors all on one heatsink, does the TDA2030A need to have a heatsink as well?(not enough space on the one i have to add it with the transistors). The reason I ask is I dunno if the transistors do most of the work or just help out the TDA a bit with the excess.
Thanks in advance
Thanks in advance
