TDA 7296A - any higher quality replacement?
Guys, I do wonder, if the TDA 7269A amplifiers has some pin-compatible replacements that offer higher quality.
I hear the LM3886 or LM3775 are far superior, but can be, for example the LM3886 schematic made compatible with TDA 7269A with no major changes?
TDA 7269A - http://www.ges.cz/sheets/t/tda7269a.pdf
LM3886 - http://www.ges.cz/sheets/l/lm3886t.pdf
BUT:
Their pins are not compatible at all 🙁
Also I think it would be wise to check on these amps possible replacements:
TDA 7296
TDA 7360
Any suggestions?
