Hi all,
I'm designing an audio amplifier with the TAS5706A I2S input Class D:
http://www.ti.com/lit/gpn/tas5706a
I'd like to run the Class D at 12V to produce ~9W output, which seems OK. I suspect I'll need a 12V supply that is capable of up to 1A.
The input voltage to the system is +48V DC.
I have two questions
Any help would be much appreciated.
- Should I be looking for a linear or a switched power supply for the 12V? Audio quality is the main concern.
- Is it better to keep the regulated 12V output separate i.e. not use it as an input to post regulators for other components?
Are class D best option
Dear BornToLag,
I have no experience with Class D. so cant answer, but at only 9W a class A amplifier is very practical.
I would imagine you have a lot of Class D amplifier experience and a good reason for using class D, and I am curious why you made this choice.
A JLH 1969 class A amplifier would not be prohibitively expensive (if time and effort are a consideration in production costs)
Owen
Dear BornToLag,
Owen
