omron relay spec
Coil Current:11.5mACoil Resistance:4.17kohmCoil Type
C, MonostableCoil Voltage VAC Nom:48VCoil Voltage VDC Nom:48VContact Configuration
PCOContact Current Max:5AContact Voltage AC Nom:250VContact Voltage DC Nom:30VExternal Depth:25.5mmExternal Height:29mmExternal Width:13mmNom Operating Power:530mWRelay Mounting:Through HoleRelay Type
owerApproval Bodies:CSA / SEMKO / SEV / ULCoil Operating Lower Percent Limit:70%Coil Operating Upper Percent Limit:110%Contact Current AC Max:5AContact Current DC Max:5AContact Voltage AC Max:240VContact Voltage DC Max:30VDC Coil Power:530mWExternal Length / Height:29mmMounting Type
CBNo. of Poles:2Operating Temperature Max:70°COperating Temperature Min:-40°COperating Time:15msRelease Time:15msSeries:G2RSwitch Current Max:5ASwitching Current Max:5A
