Hi folks
I've ordered an MG-1.1 Airbearing tonearm but a couple of folk have said putting a tangential tonearm on a suspended turntable is a mistake.
If the arm is attached to the subchassis in the normal fashion then in theory the weight transfer of the arm across the turntable might affect the level of the platter and arm. If everything is set level with the arm in the centre of the record a slight weight bias to the ouside would be present at the start of play and to the inside toward the end of the record.
In practice does this make a detectable difference?
I've got a solid concrete floor and spiked stand so foot fall is not an issue.
Thanks in advance.
Steve
Thanks in advance.
Steve
