Am thinking of building a small sub using the 6.5" TangBand, but after taking a look at it's 8" brother:
http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=264-833
It has some very interesting t/s parameters, making its optimal sealed volume about 0.135cuft and vented its about 0.22cuft
Can the enclosure be really this small? Or is this some extreme case where the t/s parameter fails? It will be great if anyone with practical experience of the TB 8" can share your findings.
If the t/s parameters are correct, then I will like to try a 2xdrivers in a push-pull configuration. This should lead to a very small (10"x10"x7") and relatively vibration free box...
