For Sale TacT Audio S2150X Digital Amplifier
Things you have for sale.
Hey all,
I have a Tact S2150X Digital Amplifier (Silver Faceplate) with volume remote for sale, It has the Equibit chipset, and has Digital only inputs (no analog inputs)...basically an integrated PowerDAC. Its 150 watts @ 8 ohms and 300 watts @ 4 ohms. Amp also has the ability to do high or low pass crossover outputs.
The amp firmware has the latest version (unfortunately, the latest firmware REMOVED the Room Correction ability that the peramps have - why would they do this?)
Works great - I have two, but will be holding onto one. Also have a Tact RCS 2 Preamp (Black Faceplate) that does the room correction also available...
Asking $725 + ship...
Specs:
Power (RMS. per channel) 8 ohm 2 x 150W Power (RMS. per channel) 4 ohm 2 x 300W
Output current (peak, per channel) >50 A
Signal-to-noise ratio ( A-weighted) >110dB
Dynamic range (20 Hz - 20 kHz) >130dB
THD+N (all power levels 20Hz-20kHz) <0.01%
Digital resolution 16-24 bit Linearity (-120dB) +- 0,2dB
Dimensions (WxHxD) 450x140x420 mm 17.7x5.5x16.5 in.
Weight (shipping) 18 kg / 37 lbs
Reactions: taloyd
