T amp vs 16ohms?
I've got a Super T and am planning to run four 8ohm speakers, two per side in parallel. The amp will be driving into a nominal 16ohm load.
Will this be a problem for the amp?
Will it cause a shift in tone?
I do not play at high volumes... usually.
